Belimed - MST V 6 Series
by Belimed
Medium Chamber Steam Sterilizer
The MST V 6 Series of steam sterilizers is optimized for throughput and workflow efficiency. MST V sterilizers can be installed side-by-side, with no side or rear service access required, making lean, extremely space efficient department designs possible. With a capacity of up to 12 standard trays, a width of less than 40 inches, and options for fully integrated steam generators, the MST V sterilizer is the most efficient and compact sterilizer in its class.
FORUMSView All (4)
-ysfacr
a month ago
ethernet connection with pc and pc program required
I changed the p1 and p2 pressure transducers, I need to connect with a pc to verify the calibrations, thank youReply
-DFMK6
2 years ago
service modes passwords
Hello All, Does anyone have the service mode passwords available? Thank you.Reply
2
-DanD
3 years ago
Divergence P1+P2
Is there any outside/external condition that can cause this error.Reply
  • Ideal for OR’s, surgical centers, and sterile processing departments.
  • Three sizes available to meet your individual processing needs
  • Designed to be installed side by side allowing efficient use of tight space requirements.
  • Electric boiler available providing contaminate free steam (Clean Steam), reducing the need for expensive chamber maintenance and extending the life of medical instruments
  • Ergonomically designed for ideal loading and unloading, easing staff back strain and repetitive motion.
OrientationFloor Standing
