BMI Biomedical - JOLLY-PLUS
by BMI Biomedical
Multifunctional mobile radiographic unit
1ReplyTue Jul 22 2025 | Touch screen problem JOLY 20 PLUS I have a JOLY 20 PLUS device that suddenly does not respond to commands on the touch screen, however, when turning it on, I press the setup button and it changes color, so I suspect it is not a problem with the touch device. Reply |
1ReplySat Jul 12 2025 | kv values 85% lower Has anyone encountered this error? When turned on, it only allows you to take one photo, but then it shows this error and so on every time. Maybe the monoblock is already dead? Reply |
0RepliesTue Jun 18 2024 | Dépannage lors qu'on veut déclencher les rayon l'écran affiche cette erreur "Condensateur sous charge" Equipment: BMI Biomedical - JOLLY-PLUS Reply |
[list] [*]Easy moving and positioning [*]Touch screen Control Console [*]Simple use both in manual and A.P.R. mode [/list]
Output Power: 4 kW to 30 kW
