Infusion Pump
Clear color identification of infusion route from the pump to the patient via yellow colored code along the infusion set.
- A higher pressure limit range.
- A range of dedicated transport bags for external container infusion
- Custom made menu with or without Bolus/Dose limit/Loading dose to fit therapy protocols and avoid set up errors.
- Easy review of patient history thanks to easy-to-read history menu on the pump graphical display or the handy portable printer.
- Simplified set up menu for 3 steps start procedure: Enter Rate+Volume to infuse and Start infusion.
- Incorporates “Preventive Maintenance” management
- The pump has been designed to decrease most of unnecessary potential alarms whilst preserving full safety:
- No air alarm thanks to the air in line eliminator incorporated in all sets.
Automatic restart after occlusion release.
- Long battery autonomy (7 days at 2ml/h) to decrease the frequency of battery alarms and related changes.
- Small, ergonomic and compact for true and comfortable ambulatory therapies.
- Pump size already includes the drug volume (up to 160ml)
- Outstanding battery autonomy.
| Volume to be Infused | 1 to 999 ml |
| Flow Rate Range | 0.1 to 100 ml/h |
| Weight | 290 g with battery |
| Flow Accuracy | 5 % |
| Infusion Pump Type | Patient-Controlled Analgesic (PCA) |
| KVO Range | 0.1 to 2 ml/h |
Delivery Modes: Continuous, Bolus only, Continuous + bolus
Programming units Concentration: 0.1 to 99.9 mg/ml
