Hillrom - Progressa
Introducing the new Progressa® bed system for the ICUThe Progressa® bed system responds to the evolving needs of caregivers, patients and health care facilities. More than just a bed, the Progressa® bed system is a therapeutic device that acts as a seamless extension of the health care team.
FORUMSView All (13)
0Replies5 months ago | Surface air leak I have a P7500 and the lower third of the mattress will not hold air. How would I find the air leak Equipment: Hilrom - Progressa Reply |
0Replies8 months ago | Wheel Replacement Does anyone have the IPB (for the non-seasoned techs - Illustrated Parts Breakdown) of the base for the wheel removal and replacement? Reply |
0Repliesa year ago | Fitted Sheets Progresss Hillrom bed not using fitted sheets per manufacturer recommendations but lots of complaints from patients and staff with flat sheet crumpling under Meath patient, or patient skin touching mattress. Suggestions?Reply |
SERVICE COMPANIESView All Bed Companies
[list] [*] Patient Mobility - The Progressa® bed system provides features and functions that help support early mobility [*] Patient Repositioning - Available only with the Progressa® bed system, StayInPlace™ Technology extends the head section of the frame and surface, in unison, to accommodate the natural elongation of the body as the patient sits up [*]StayInPlace™ Technology is designed to help address patient migration to the footend of the bed [*] Platform Scalability - The flexibility of the Progressa® bed system platform allows you to configure the bed to your current needs and make upgrades as those needs change [/list]
Height | 35 in |
Length | 88 in |
Width | 40.5 in |
Standard Caster: 6 in" (15.24 cm) C-Arm Clearance: 7-15" (17.8-38.1 cm) Radiolucent Sleep Deck Standard: 17.7" x 23" (45 cm x 58.5 cm) Head Articulation: 0°-67° Thigh Articulation: 0°-30° Foot Articulation: 0°-70° Trendelenburg: 13° Reverse Trendelenburg: -18°
