Hillrom - Progressa
by Hillrom
The Progressa® bed system responds to the evolving needs of caregivers, patients and health care facilities. More than just a bed, the Progressa® bed system is a therapeutic device that acts as a seamless extension of the health care team.
1ReplyThu Jun 26 2025 | Progressa bed motor moves in reverse when you're trying to go forward replaced two boards checked all the wires, Rebooted. Any ideas Equipment: Hillrom - Progressa Reply |
0RepliesWed Apr 02 2025 | MCM valve current counts under MCMSO current minimum 0x30C7 Hello currently I have a progressa bed with this problem “MCM valve current counts under MCMSO current minimum 0x30C7” I have tried calling hillrom support for help but they told me I have to pay for there services. What should I do? Equipment: Hillrom - Progressa Reply |
1ReplyWed Jan 01 2025 | Indicator Light Why is my indicator service light on? How do I know what needs to be serviced? Equipment: Hillrom - Progressa Reply |
[list] [*] Patient Mobility - The Progressa® bed system provides features and functions that help support early mobility [*] Patient Repositioning - Available only with the Progressa® bed system, StayInPlace™ Technology extends the head section of the frame and surface, in unison, to accommodate the natural elongation of the body as the patient sits up [*]StayInPlace™ Technology is designed to help address patient migration to the footend of the bed [*] Platform Scalability - The flexibility of the Progressa® bed system platform allows you to configure the bed to your current needs and make upgrades as those needs change [/list]
| Height | 35 in |
| Length | 88 in |
| Patient Weight Capacity | 500 lbs |
| Width | 40.5 in |
Standard Caster: 6 in" (15.24 cm) C-Arm Clearance: 7-15" (17.8-38.1 cm) Radiolucent Sleep Deck Standard: 17.7" x 23" (45 cm x 58.5 cm) Head Articulation: 0°-67° Thigh Articulation: 0°-30° Foot Articulation: 0°-70° Trendelenburg: 13° Reverse Trendelenburg: -18°
