Smiths Medical - CADD-Legacy PCA
by Smiths Medical
The CADD-Legacy PCA pump is the member of the new CADD-Legacy pump family
CADD-Legacy® PCA Ambulatory Infusion Pump, Model 6300 for continuous clinician-activated bolus and patient-activated bolus infusions.
FORUMSView All (3)
-BioPhiled
2 years ago
LEC 1310 [Last Error Code] Clear
LEC xxxx always displays at boot up even when issue has been resolved. Is there a way to reset the error log?Reply
-Danlittle1
10 years ago
Error Code 57
What does error code 57 mean?
-Frank516
11 years ago
service due
Is there any way to service the 6300 to get the Service due to go away?
[list]            [*] Easy to Read Display  - Easy to read and understand display screen provides information for programming adjustments and troubleshooting. New display messages, such as    [*] Cassette Detection - Cassette detection sensor is designed to detect cassette attachment    [*] Occlusion Detection - Upstream and downstream occlusion sensors are designed to alert the patient and clinician if interruption of fluid delivery occurs    [*] Air-in-Line Detection - Air-in-line detector with Off, High- and Low-sensitivity settings is designed to alert the patient and clinician if air is present in the administration set tubing    [*] ON/OFF Key  - ON/OFF key allows pump to be placed in low-power state and is designed to save battery life     [*] Event Memory   - The last 1,000 events in the pump's history can be downloaded either directly or remotely (using a modem) to a PC using the CADD-DIPLOMAT® PC Communications System    Reliability  - CADD® pump reliability and durability can mean less down time and fewer interruptions to therapy    [*] Programming Flexibility  - Convenient programming in milliliters, milligrams or micrograms and expanded concentration ranges    [/list]
Weight392 g
Flow Accuracy6 %
Infusion Pump TypeAmbulatory
KVO Range1 to 125 ml/h
