Smith and Nephew - SPIDER2 Limb Positioner
Patient positioning fo shoulder, knee and extremities surgery.The SPIDER2 Limb Positioner allows proper patient positioning for shoulder, knee and small joint arthroscopy. The integrated positioning switch rids you of tedious manual adjustments and readjustments during surgery.
1Reply8 years ago | tenet spider 2 operating manual Reply |
- An integrated patient-positioning switch is located on the sterile drape for easy access.
- The distal activation switch eliminates the need for a foot pedal (provided as option).
Increased Rigidity - System maintains a steady position from start to finish.
Lightweight System with Universal Clamp - This easy-to-maneuver, lightweight* system can be used with all types of surgical beds while eliminating the need for adaptors.
Battery Powered - Surgery is no longer dependent on OR settings for air pressure; this chargeable battery provides power suited for use in domestic or international facilities.
Advanced Sterile Drape with Distal Activation Switch
