Draeger - Caleo
Infant Incubator
Caleo® works to deliver an ideal microenvironment for neonates by delivering the appropriate temperature, humidity, oxygen levels. It is designed to create a microclimate that minimizes the effect of disturbances and time out of the Thermo-Neutral Zone. Double air curtain acts as a security blanket for the neonate, providing a balanced climate even when access doors are open. Continuously measuring both central and peripheral body temperature. Truest, most accurate early indicator of cold or heat stress, or temperature instability. Caleo® offers caregivers and parents easier, closer access to a premature baby while balancing the baby’s need for a stable, controlled microclimate with your need for continuous access, especially in an emergency. Caleo’s generously designed JumboPorts™ gives full, climate-controlled access to any part of the bed so that endotracheal intubation and minor surgical procedures can be carried out inside the incubator.
FORUMSView All (7)
2Replies4 years ago | height control interruption Hi. I have a little issue with a caleo, when you try to rise the trolley, it does not activated, you need to try first to press the descent pedal, to "activate" the ascent pedal. Reply |
1Reply6 years ago | Error 52 I have a Caleo incubator with error 52. Caleo turn on fine at first time and begin to heat but after something like 30 min fail and show Error 52 (communication error between WT2 Controller and WT2 sensor). I have exchanged both WT2 with another functional machine and problem persist. I have replaced LAN cable to connect WT2 sensor with WT2 actuator and error persist. Any suggestion?Reply |
2Replies6 years ago | incubator dragger caleo wont turn on Hi, i do the troubleshooting, check the fuses and the power cord and they are good. could it be the power supply the problem? and how i remove it?Reply |
