Steelco - AD 400
by Steelco
Steelco AD 400 drying cabinet is available in single door or double door pass-through version with glass door for a rapid visual inspection of the stored item. Steelco AD 400 drying cabinet provides fast drying of instruments, equipment and general items. It has dedicated connections allowing forced drying of anesthetic instruments. Items are stored in controlled environment thanks to the circulation of HEPA H14 filtered air flow. [b]Cassettes[/b] The hoses are connected to the cabinet blowing system thanks to removable cassettes that allow easier item loading and proper internal forced air flow.
0Replies6 years ago | motor or engine someone knows about the engine or motor of this item ? thank you Reply |
[list] [*] Drying/storage chamber: 600 x 600 x 1400h mm / 23.62” x 23.62” x 55.12”h [*] Lockable doors are reversible and configurable right or left opening also during installation. [*] nr. 3 AN cassettes for a total capacity of 36 anaesthesia hoses [*] nr. 8 DIN 1/1 trays on 8 removable shelves [*] Additional shelves can be added as option as well as luer lock air connection for laparoscopic instruments. [/list]
| Height | 1900 mm |
| Length | 710 mm |
| Width | 785 mm |
