Steelco - EW 2 2S - 3S
Synchronous reprocessing capacity of 2 or 3 flexible endoscopes: single door and double door pass-through versions.[list] [b]Unrivalled reprocess capacity[/b] EW 2 2S: up to 2 endoscopes - up to 9 videobronchoscopes per batch EW 2 3S: up to 3 endoscopes - up to 6 videobronchoscopes per batch [b]Best capacity/footprint ratio[/b] sliding down doors & frontal maintenance [b]Lowest cost per batch [/b] reduced water and chemical consumption Steelco EW 2 2S and EW 2 3S are dedicated to low temperature washing and high level disinfection of flexible endoscopes it has been devoleped for treatment of all types and model. The new Steelco EW 2 2S and EW 2 3S AERs fully comply with the ISO 15883-1/5 directives and incorporates all the latest innovative technologies. Can be supplied in a pass-through interlocked double door version, or single door. Complete cleaning and disinfection cycle time in 25 minutes only. Ergonomic and effortless general operation EW 2 2S and EW 2 3S AERs are equipped with sliding drawers that allow the easy instruments loading and unloading operations. Single hand operated instrument/AER connection [/list]
[list] [*] Compatible and tested with peracetic acid (cold disinfection) and glutaraldehyde (chemo-thermal) [*] User and instrument recognition through bar code reading system or RIFD (Radio Frequency Identification). [*] Leak test at the beginning of the cycle and continuous monitoring during all cycle phases with automatic cycle stop in case of anomaly. [*] Precise endoscope channel-check (up to 7 channels for each endoscope ) with two independent monitoring systems through pressure and flow measurement and data logging during the whole cycle. [*] Disinfection of all the water used in the process with a two stage high level water filtering (0,5 Μm and 0,1 Μm filters) for endotoxin removal. [*] Integrated sterile air filter for channel leak test, purging and drying. [*] Self thermal disinfection cycle at 90°C as required from the UNI EN ISO 15883-4 rule including endoscope basket and connections. [*] Data logging of all program data and instrument parameters, graphically visualized as a curve. [*] Complete documentation on integrated printer or to PC/hospital server with SteelcoData software. [*] Large color LCD touch screen display for easy machine operation and endoscope/operator database management [/list]
