Steelco - ED 250
PLC controlled cabinet for the drying and storage of flexible endoscopes. Instruments hanging vertically.[b]High storage capacity[/b] up to 9 or 18 endoscopes [b]Ergonomic[/b] fully extractable vertical drawers with fast connections [b]Single door and pass-through versions[/b] suitable for barrier application [b]Event tracking and traceability[/b] visual color coded drying and storage status After being reprocessed into a AER, the endoscopes are ready to be used or stored in a drying cabinet which protects them from recontamination. Warm sterile air is blown through each internal channel and over all surfaces, to rapidly dry both the inside and outside of the flexible endoscopes. Steelco ED drying cabinets can be fitted with a bar code reader and printer for logging scopes in and out ensuring full tracking and traceability of the scopes.
0Replies7 months ago | Error E7 Reply |
[list] [*] Capacity: up to 9 endoscopes can be stored at a time vertically hanging on easy access vertical drawers with fast connections. [*] Door made in HST temperate glass. [*] Frame and panels in stainless steel AISI 304. [*] Glass lockable doors are reversible and therefore can be configured right or left opening also during installation. [*] Single and double door (pass through) versions with control panel controlled locking. [*] High level HEPA H14 air filtering. [*] Indirect UV air treatment as option [*] Events and cycle data storage for each instrument treated and machines parameter. [*] Ethernet connection for PC data storage and compatibility with Steelcodata and SteelcoData ARES software. Storage for large endoscopy centres The ED 250 can be configured in a more compact frame that combines two devices into a single unit with central control module. In an installation width of only 1672 mm / 65.82”, up to 18 flexible endoscopes can be simultaneously dried and stored. [/list]
Height | 2270 mm |
Width | 962 mm |
