The TCM II maintains exact temperatures with sensitive, microprocessor-driven controls and minimizes patient rewarming time with powerful heaters and high-efficiency mixing manifold.
Reduces patient cooling time by melting ice. Monitors temperatures conveniently using optional remote control and display module.
- Digital Heater/Cooler
- Maintains exact temperatures with sensitive, microprocessor-driven controls
- Minimizes patient rewarming time with powerful heaters and high-efficiency mixing manifold
- Reduces patient cooling time by melting ice
- Sarns optional remote control and display module for temperature management at your fingertips while the main unit is situated in a convenient, remote location
- Temperature displays in digital readouts for up to nine temperature probes; readouts for up to 9 temperature probes by using 3 temperature modules; alarm can be set for 3 probes (one probe per module) located at crucial temperature sites
- Precise temperature controls maintained by a microprocessor which allows oxygenator water temperature selection from 0 - 42°C in one-degree increments
- Independent cardioplegia control offers three pump speeds for variable cooling rates and a separate reservoir accommodates drop-in heat exchangers
- Pressure-regulated blanket ports with water-supply maintain the same temperature as water going to the oxygenator heat exchanger
Height | 34.4 in |
Length | 31.5 in |
Weight | 282 356 lbs with the tanks full |
Width | 20 in |
Large Tank
- Length: 18.5’’ (47,0 cm)
- Width: 8.7’’ (22,1 cm)
- Depth: 21.5’’ (54,6 cm)
- Water Capacity: 9 gal (34 L)
- Crushed Ice Capcity: 40 lbs (18,1 kg)
Small Tank
- Length: 9.5’’ (24,1 cm)
- Width: 5.5’’ (14,0 cm)
- Depth: 9.3’’ (23,6 cm)
- Water Capcity: 1.2 gal (4,5 L)
- Crushed Ice Capcity: 7.5 lbs (3,4 kg)
Temperature Display Unit
- Length: 8.75’’ (22,2 cm)
- Depth: 2.5’’ (6,4 cm)
Temperature Probe Modules
- Length: 9.0’’ (22,9 cm)
- Width: 5.75’’ (14,6 cm)
