Embedding System
The Leica Biosystems EG1160 Paraffin Embedding Center is a compact, microprocessor-controlled tissue embedding system designed to deliver precision, efficiency, and reliability in histology and pathology labs. Engineered for ease of use and consistent performance, the EG1160 ensures reproducible paraffin dispensing and optimal specimen orientation.
With programmable temperature controls, flexible workflow settings, and an ergonomic design, this system streamlines embedding processes while maintaining high safety and quality standards. The remanufactured EG1160 offers a cost-effective solution without compromising performance, making it ideal for laboratories seeking dependable tissue processing equipment. (Generated by AI)
Ask a New Question1Reply-EmilB Fri Aug 04 2023 | Fri Aug 04 2023Instrument not turning on.
The instrument will not turn on. The LCD is not displaying anything. The main power switch turns on, illuminates, and the two 10 A fuses on the back test fine. I've measured ~120 V AC on the terminal bar inside the back. I've tested all of the fuses I can find after removing covers, and all have continuity. I tested continuity of the on/off switch and it opens and closes fine. It reads 15 V AC at each of the switch posts though. Any suggestions would be appreciated.
Reply |
2Replies-Yongjun Fri Nov 25 2022 | Fri Nov 25 2022Error #02 Error #02 and no cooling and heating, anyone knows the reason and solution?Reply |
1Reply-McGyver Tue Nov 23 2021 | Tue Nov 23 2021Service Manual Where can I find service manual?Reply |
VIDEOS
Tissue Embedding using Leica EG 1160
Precision Paraffin Dispensing
- Separately Heated Dispenser: Ensures consistent paraffin flow
- 10 Flow Rate Settings: Adjustable for precise embedding control
- Integrated Filter System: Maintains clean, reproducible paraffin output
- Multiple Activation Options: Manual, footswitch, or mold-activated dispensing
Advanced Temperature Control
- Programmable Heating Zones: Paraffin reservoir, cassette bath, mold warmer, and work surface
- Stable Temperature Regulation: Supports consistent embedding conditions
- Cold Plate with Refrigeration Spot: Facilitates precise specimen orientation
User-Friendly Operation
- Microprocessor-Controlled System: Easy, one-touch programming
- Custom Scheduling: Programmable workday, start/end times, and real-time settings
- Multilingual Interface: Supports German, English, French, Spanish, and Italian
- Battery-Buffered Memory: Retains settings during power interruptions
Ergonomic & Efficient Design
- Compact Bench-Top Footprint: Ideal for space-limited labs
- Illuminated Workspace: Enhances visibility during embedding
- Removable Cassette Bath: Simplifies cleaning and maintenance
- Heated Forceps Holders: Included on the right, optional on the left
- Paraffin Level Indicator: Enables efficient workflow management
(Generated by AI)
| Height | 320 mm |
| Weight | 50 kg |
| Width | 910 mm |
- Product Type: Tissue Embedding Center / Paraffin Embedding System
- Model: EG1160
- Control System: Microprocessor-controlled
- Paraffin Reservoir Capacity: 3 liters
- Flow Rate Settings: 10 adjustable levels
- Heating Zones: Reservoir, cassette bath, mold warmer, work surface
- Cold Plate: Integrated with refrigeration spot
- Dispensing Methods: Manual, footswitch, mold activation
- Programming Features: Workday scheduling, start/end times, real-time clock
- Languages Supported: 5 (EN, DE, FR, ES, IT)
- Memory: Battery-buffered
- Design: Compact bench-top unit
- Condition: Remanufactured to high-quality standards
- Applications: Histology, pathology, laboratory tissue processing
(Generated by AI)
