Leica Biosystems - HistoCore Arcadia H
Embedding System
The HistoCore Arcadia H allows for simple operation and precise control; resulting in improved quality, a smooth workflow, reliability and speed of your embedding work. Features include wrist pads for increased comfort and stability; an improved magnifier for small biopsy embedding; and an LCD touchscreen for increased control and monitoring of the instrument.
FORUMSView All (7)
0Replies20 days ago | Wax bath temperature high The wax bath temperature is 3C deg higher than the set temperature. how do I get into the sensor calibration mode? (and as always...anyone found the Service manual? (no, not the User Manual)) Reply |
0Repliesa year ago | Error Code 2_31 Does anyone know how I can get rid of the error code? I know that it means that "The temperature of the left tray is higher than the upper temperature limit." The temperature setting has been turned down and I have rebooted the instrument a few times already but it is still giving me an error code. TIA! Reply |
0Replies3 years ago | Part number required... Can anyone advise the part number for the replacement dispense arm for the Histocore Arcadia H?Reply |
- Modular System- The HistoCore Arcadia modular tissue embedding system incorporates two separate components, the Arcadia H heated embedding module and the Arcadia C cold plate. The independent modules offer the flexibility to arrange the embedding workflow in the direction that best suits your laboratory.
- Smooth Workflow- The symmetrical and unobstructed workspace reduces distractions and allows you to keep your cassettes, molds and other accessories warm and at hand for a smoother workflow. Easy-to-open trays allow for efficient access to cassettes and molds, resulting in smoothly run batches.
- Simple operation- The bright white LED improves contrast and visibility of the most transparent samples. The use friendly magnifier, with its wide lenses and straightforward positioning, helps you embed the smallest and most complex biopsies.
- Easy to clean- The Arcadia H has an easy to clean metal frame and silicon coated wristpads. The sturdy design of the special scraper helps clean all groves and crevices.
- Precise control- Control matters. The ergonomic wrist pads increase hand stability and precision, even when embedding the most difficult biopsies.
Height | 385 mm |
Weight | 25 kg |
Width | 560 mm |
