Leica Biosystems - HistoCore Arcadia C
Embedding System
HistoCore Arcadia C is a cold plate holding more than 60 cassettes on its large working surface. Cooling efficiency is important, so the cold plate was designed with an environment adaptive control module to make sure the operating temperature is always stabilized at -6 °C. There is no need to turn down the temperature in summer or worry about too fast cooling in winter.
The Arcadia C cold plate can be used as a stand-alone unit for re-cooling blocks prior to sectioning or as part of an embedding center to cool molds after paraffin dispensing.
3Repliesa year ago | Beeping intermittently but works fine Hey guys! I have cold plate that works perfectly fine but beeps intermittently... Not sure why, would anyone have a service manual? TIA!Reply |
- Modular System- The HistoCore Arcadia modular tissue embedding system incorporates two separate components, the Arcadia H heated embedding module and the Arcadia C cold plate. The independent modules offer the flexibility to arrange the embedding workflow in the direction that best suits your laboratory.
- Smooth Workflow- The symmetrical and unobstructed workspace reduces distractions and allows you to keep your cassettes, molds and other accessories warm and at hand for a smoother workflow. Easy-to-open trays allow for efficient access to cassettes and molds, resulting in smoothly run batches.
- Simple operation- The bright white LED improves contrast and visibility of the most transparent samples. The user friendly magnifier, with its wide lenses and straightforward positioning, helps you embed the smallest and most complex biopsies.
- Easy to clean- The Arcadia H has an easy to clean metal frame and silicon coated wrist pads. The sturdy design of the special scraper helps clean all groves and crevices.
- Precise control- Control matters. The ergonomic wrist pads increase hand stability and precision, even when embedding the most difficult biopsies.
Height | 385 mm |
Weight | 30 kg |
Width | 400 mm |
