Smiths Medical - Graseby 2000
by Smiths Medical
Infusion Pump
The Graseby™ 2000 range of syringe pumps provide simple, reliable and easy to use infusions for a range of clinical therapy areas. Both pumps deliver medication as a continuous infusion at offer affordable quality from a name you can trust. Recognised in operating theatres, intensive care units and general wards across the world, Graseby™ infusion pumps have been trusted by healthcare professionals for over 30 years.    Both the Graseby™ 2000 and the Graseby™ 2100 syringe pumps provide simple, reliable and easy to use infusions for a range of clinical therapy areas. Both pumps deliver medication as a continuous infusion at rate between 0.1ml/h to 1200ml/h depending on the syringe size.    If required, a preset volume to be infused (VTBI) may be programmed. The Graseby™ 2100 pump also features Body Weight programming which enables clinicians to programme using mass units where required.
-MedWrench Crystalyn
Mon Oct 25 2021
Smiths Medical Graseby 2000
Smiths Medical Graseby 2000Reply
-DarrenRai
Mon Oct 25 2021
Smiths Medical GRASEBY Omnifuse Syringe pump - software required
Hello, Looking for syringe pump Technician PC software - pump is obsolete but we are readying a batch of pumps for donation to Africa, would be much better if they can be calibrated before they are sent over - any assistance greatly appreciatedReply
VIDEOS
  • Easy to use- On-pump syringe loading guidelines to provide support to clinicians at the bedside
  • 4-step programming sequence allows quick and simple programming
  • Graseby™ 2100 body weight mode automatically calculates the infusion rate to assist the clinician
  • Versatile-Wide programmable infusion rate range between 0.1 and 1200ml/h allows the pump to be used across a range of clinical settings providing familiarity and consistency to clinical teams
  • 3 adjustable occlusion pressure settings allow the pumps to be tailored to the specific requirements of the therapeutic care area.
  • Added Safety- Post occlusion bolus reduction to help reduce the likelihood of over infusion
  • Wide range of alarms promotes clinician awareness and prompts intervention where necessary
