VWR - Clinical 200
Designed for ease of use, this large-capacity centrifuge is ideal for clinical lab and research environments.A combination of digital displays and easy-set knobs allow for quick and precise setting of operating parameters. Precise operational control is maintained by the microprocessor. An imbalance sensor is incorporated into control the loop to stop operation of centrifuge in case rotor is loaded improperly. At end of run, dynamic braking brings rotor to quick and turbulence-free stop.
Four rotor options are available. Optional adapters accommodate various tube sizes including standard round-bottom blood tubes. Safety lock lid prevents opening during use. Centrifuge may be used in a cold room. Hematocrit tube reader measures hematocrit values with tubes still in rotor; device is placed on top of rotor and corresponding value is read from graph.
FORUMSView All (5)
2Replies3 years ago | Won't reach set speed? I haven't used this centrifuge for quite a while. It is an older (2006) version of the VWR 200. I have set the speed to 5000 rpm, it has the 6-place 50 ml angle head rotor installed. The speed tops out at 665 rpm. What can I do to remedy this situation? Initially the LED screen was flashing "94" . I unplugged it and plugged it back in again, and the screen now functions normally. Reply |
6Replies3 years ago | Won't reach set speed. I haven't used this centrifuge for quite a while. It is an older (2006) version of the VWR 200. I have set the speed to 5000 rpm, it has the 6-place 50 ml angle head rotor installed. The speed tops out at 665 rpm. What can I do to remedy this situation? Initially the LED screen was flashing "94" . I unplugged it and plugged it back in again, and the screen now functions normally.Reply |
1Reply5 years ago | What are the spec's on this device all the manual says is max speed of 6,000 pm What are the spec's for this device? All the manual says (which very little) is 6,000 RPM maxReply |
VIDEOS
- For Clinical Lab and Research Environments
- Microprocessor Control
- Safety Lock Lid
- Dynamic Braking with Non-Disruptive Soft Stop
- VWR Two-Year Limited Parts and Labor Warranty
Height | 26 cm |
Orientation | Benchtop |
Weight | 15 kg |
Centrifuge Type | Clinical |
Maximum Speed | 6000 rpm |
Width | 28 cm |
