Cincinnati Sub-Zero - Norm-O-Temp
The Norm-O-Temp hyperthermia treatment unit is a cost effective solution when a dual-application hyper-hypothermia system isn't needed.
The Norm-O-Temp is a whole body hyperthermia system that allows conductive warming therapy to be administered. It can be used in the operating room, pre-op, recovery, emergency department or any department in need of patient warming therapy.
FORUMSView All (6)
1Reply5 years ago | Temp is about a bit out of tolerance All, One of my techs have been checking these and the temps are just a bit low and out of tolerance. There doesn't seem to be any calibration procedures, so does that require a board change? Reply |
1Reply11 years ago | BIOMED TECHNICIAN HOW OFTEN SHOULD THE WATER BE CHANGED IN THE NORM-O-TEMP? Reply |
1Reply11 years ago | Err during post at the end of power on self test display shows Err with audible alarm beeping that will not mute Reply |
SERVICE COMPANIESView All Warming/Cooling Unit Companies
Benefits
- Microprocessor controlled
- Helps maintain normothermia
Features
- Pre-warming feature
- Compact size helps save space
- 2 Blanket connections
- Easy to use interface
Height | 18.5 in |
Length | 15 in |
Weight | 33.5 lbs |
Width | 9 in |
Water Temperature: 20°C to 42°C
Flow Rate: 27 gph (102.2 lph) with blanket, approx.
Fluid Temperature Range: 20°C to 42°C for 100/115V units
NEWSView All
Corporate Profile: Cincinnati Sub-Zero
Cincinnati Sub-Zero (CSZ), a leading provider of temperature management equipment for over 70 years, serves medical and industrial industries with high quality temperature management products and services worldwide.
