Cardiac Science - Quinton ST55
Treadmill
Designed to operate specificaly with Quinton stress test monitors, these treadmills are identical except for the length of the walking surface: the ST55 has a 55-inch long surface. This system also delivers consistently high torque over the entire treadmill speed and patient weight range to deliver the speed accuracy required for stress testing. The speed range is 0.8 to 9.6 mph, the weight maximum is 400 lbs and the grade is adjustable from 0 to 25%. In addition, the quiet operation makes these treadmills ideal for hospital and office environments.
0Replies8 years ago | QUINTON T55 I HAVE A QUINTON TM 55 AND THE COMPUTER DIDNT DETECT THE TREADMILL, SO WE CHNAGE THE SERAIL PORT WIRE FROM THE COMPUTER TO THE TREADMILL. THEN WE CHANGED THE SERIAL PORT ON THE TREADMILL, AND ON THE COMPUTER, THEN CHEKED ALL THE CONECTORS BETWEEN THE COMPUTER AND EVRYTHING WAS OK WE TESTED THE STOP BOTON OM THE HANDRAIL AND IS OK
AND THE COMPUTER IS STILL NOT DETECTING
COMUNICATION 1 IS WERE THE TRADMILL IS CONECTED AND IS SET ON THE SOFTWARE OF THE COMPUTER
WHAT DO,YOU THINK WE CAN DO ? Reply |
- Features digitally controlled AC-drive system that delivers greater performance, improved accuracy, and increased reliability.
- Speed start at .8 mph to 9.6 mph.
- 400 lb user weight capacity.
- Length: 80.2” (204cm).
- 115V/20A power required.
- Dedicated circuit required.
