Cincinnati Sub-Zero - Portable Cold Therapy
The portable cold therapy unit is designed to deliver 10 hours of continuous cryotherapy offering three levels of treatment.
The portable cold therapy unit from CSZ is the only water and ice unit that provides up to 10 hours of continuous and effective cryotherapy. Since the pump on the patented portable cold therapy unit is mounted externally, it does not cause ice to melt and therapy lasts longer.
- Versatile - With a variety of specially designed pads, and options like the automobile adapter, strapping system for back, hip, and knee, CSZ's portable cold therapy system can provide cold therapy wherever and whenever it's needed.
- Easy to Use - Unlike other units which must be raised to the level of the pad for adequate pumping and taken off the bed bracket for lid access, this portable cold therapy system can be operated from floor level and filled while hanging in place.
- Reduces pain and the amount of medication needed
- Reduces edema
- Accelerates the healing of damaged tissue
- Promotes blood coagulation
