Radcal - Accu-Pro
by Radcal
This product is Discontinued
For Radiography, Fluoroscopy, Mammography, CT, Dental and Survey. Accu Pro is a member of the Accu Family Instruments.
The CT Dose Ion Chamber Sensor, recommended by AAPM Report 111, delivers precise dose measurements for modern wide-beam helical CT scanners. For mammography, the kVp sensor calibrates Hologic Selenia W-Rh and Ag tube kVp values, while the 10X6-6M ion chamber provides gold-standard dose accuracy for all anode-filter combinations. (Generated by AI)
Note: This product has been discontinued
-TJCS
Mon Jul 11 2016
RadCal Accupro kV block (40X12-W) Error Code
Does anyone know that "Exposure too strong" could be?
Ok up to 70 kV then we get the error message. Standard testing (as we have always done) same error on 2 different base units & different cables plus different x-ray units.
Thanks
  • Compact, portable design for fast setup and easy use
  • Accurate QA and Critical Acceptance Testing for CT and mammography systems
  • Performs scatter and FDA leakage tests
  • Compatible with Accu-Dose ion chambers, Accu-kV sensors, and mA/mAs measurement tools
(Generated by AI)
