Draeger - Vista 120
The Vista 120 offers essential monitoring capabilities at an exceptional value and meets the needs of a variety of care environments for adult, pediatric and neonatal patients. The 380 mm (15 inch) color touch screen provides a clear view of vital patient data, and the quick access menu, hard keys and rotary knob enable easy navigation for the clinician.
2Replies4 years ago | Connect LAN How can I connect Drager Vista 120 to LAN and remoted by WindowsReply |
1Reply6 years ago | KHURRAM SHAHZAD I WANT TO KNOW THE ABOUT THE VISTA 120 MANUFACTURING SITE Reply |
Essential monitoring capabilities [*] Available in three models, the Vista 120 displays 8 waveforms in an easy-to-configure layout. A core set of essential parameters comes standard on all models: 3/5 lead ECG, SpO2, non-invasive blood pressure, respiration and dual temperature. In addition, advanced parameters are available, including two invasive blood pressures and etCO2, depending on the model. Supports workflow efficiently and cost-effectively [*] The Vista 120 is easy to learn and easy to use. The bright 380 mm (15") screen provides a clear view of patient data, even from a distance. You can configure the display to see the information you want to see, the way you want to see it. Fast access keys and simplified menus put the data you need right at your fingertips. A nurse call interface allows connection to most hospital call systems. For workflow flexibility, the Vista 120 can be mounted on a ventilator, to an anesthesia machine, or on the wall. Comprehensive set of accessories [*] Each Vista 120 monitor includes a starter set of accessories for adult patients. A wide range of accessories, including those that support pediatric and neonatal patients, are available separately as options. Part of a complete departmental solution [*] The Vista 120 supports adult, pediatric and neonatal patients in a variety of care environments – including Intensive Care Units, Operating Rooms, Emergency Departments and Neonatal Intensive Care Units. Use the Vista 120 on its own or with a complementary Dräger device, such as a ventilator, anesthesia machine or baby warmer. The Vista 120 also offers advanced parameters for the ICU, OR, ED and NICU, depending on the model you choose. Built in recorder, power supply and battery [*] The Vista 120 has an integrated recorder that prints out up to 3 channels of information – saving time by providing documentation when and where you need it. There is a built-in power supply for direct AC connection, as well as an optional 120-minute built-in battery.
Height | 316 mm |
Length | 157 mm |
Pulse Rate Range | 15-300 BPM |
Weight | 7 kg |
Temperature Range | 0 to 50 °C |
Width | 408 mm |
