Draeger - Infinity M540
by Draeger
Opens the door to a new dimension of patient mobility, connectivity, and configurability
Streamline workflows with a monitor that goes from bedside to transport in the push of a button. Leave cables and modules attached to your patient and continue monitoring parameters and alarms in real time, while recording data during travel. Use the Infinity M540 as a standalone monitor, or integrate it with hospital IT to access clinical information systems and data analysis applications.
FORUMSView All (6)
-Frank_V
4 years ago
NBP M540
How can I perform the preventive test of NBP on Drager M540? Servicemanual?Reply
-Valorie.Toth
6 years ago
Cleaning
What is acceptable to clean the following: Draeger wall mount systems Drager - Infinity M540Reply
2
-willknob
8 years ago
NBP Test
How can I perform the preventive test of NBP on Drager M540?Reply
  • System interoperability - Review hemodynamic data from the M540 and respiratory data and trends from a Dräger ventilator side-by-side on the Medical Cockpit of the Infinity Acute Care System
  • Storage of trends, events, and alarms - Access up to 72 hours of trends on a standalone Infinity M540 and up to 96 hours with an Infinity Acute Care System Medical Cockpit
  • Continuous surveillance without interruption - Connect the Infinity M540 monitor to the monitoring network through the wired docking station at the patient bedside. Remove it from the docking station to transport, and the M540 transmits data wirelessly to the monitoring network
  • One monitoring platform for the entire hospital - A single scalable Infinity M540 monitor follows a patient over the entire care pathway, from admittance to discharge
Height89 mm
Length 43 mm
Pulse Rate Range30-250 BPM
Weight2 lbs
SpO2 Range1-100%
Temperature Range0 to 40 °C
Width259 mm
