Draeger - Infinity R50 Recorder
Print a wide range of patient data and generate custom reports.Dräger offers two thermal recorders that provide documentation of stored events, alarms, waveforms and trends. The Infinity® R50 Recorder connects to the Infinity Docking Station or directly to the Infinity monitor, while the Infinity R50-N Recorder connects to the Infinity Network, independent of the patient monitor location. The Infinity CentralStation and Infinity Kappa XLT monitor support the R50-N only.
0Replies6 years ago | RJ22 - P2500 Export Protocol Port RS232 Pinout Hi, Does anybody knows the pinout for RJ22 (Export Protocol Port) to DB9 located at P2500?Reply |
[list] [*] Record alarms - The Infinity R50 and R50-N printers offer three alarm recording operating modes – auto alarm, timed manual, or continuous [*] Print a wide range of patient data - Compact and versatile, Infinity thermal recorders let you quickly and easily print a wide range of patient data. Choose your print specifications using the easy-to-read menu. Print out patient waveforms, alarms, trend-tables and graphs – plus annotations including bed label, date and time of event, alarm cause and parameter values [*] Because the recorders have two channels, you can print any two waveforms at once, as well as trend tables, trend graphs, patient annotations and more [/list]
Height | 180 mm |
Length | 110 mm |
Weight | 2 lbs |
Width | 120 mm |
