Hammarplast Medical AB - Scandmed 400-40
Electronic tourniquets
The 400-40 Single Electronic Tourniquet is equipped with NiMH (nickel-metal-hydrid) type of batteries, enabling uniterrupted use without recharging up to 4 hours. With help of the built-in pump, valves, a powerful microprocessor, memory for the latest surgical procedures and finally an electronic troubleshooter for possible faults, we believe that we have designed a safe tourniquet for the user as well as for the patient. An automatic guide shows on the display how to use the tourniquet step by step.
FORUMSView All (4)
1Reply6 years ago | scandmed 400-40 problem did you ever find a manual for the Scandmed 400-40? I am having a error 14 trying to resolve?Reply |
1Reply6 years ago | scanmed error Kevin did you ever find a manual for the Scandmed 400-40? I am having a error 14 trying to resolve?Reply |
1Reply7 years ago | help about torniquet Ihave this tourniquet , and it is alarming ERROR 10 , there is anyone who could me anything about it , because the hammarplast is worried about the costumer needsReply |
- Fast inflation and deflation.
- Battery back-up system automatically engages if C current is interrupted.
- Powerful microprocessor monitors and gives alarms visually and audible for possible hazardous conditions for the patient.
- Clear display where figures and letters can be seen from anywhere in the O.R.
- Totally self contained.
- Alarms include too low and too high pressure, low battery capacity, leaks and kinks.
- Automatic start-up test where all critical components like pump, valves, PDM board, alarms, volume of sound etc are checked in a matter of a couple of seconds. The result is shown on the display with an OK sign and the preset pressure.
- Automatic timer which signals the user on the display and with a short 2 seconds beep after 30 minutes and then every 15 minutes up to 3 hours. The volume of the sound can be adjusted. The timer starts automatically when the cuff is inflated and stops when the cuff is deflated.
- Computerized memory of the latest surgical procedures. The result can be printed out with a PC and printer.
- Easy to clean and glare resistant.
- A sturdy, durable and solid housing in stainless steel and aluminum.
Height | 210 |
Length | 215 |
Weight | 4.3 kg |
Width | 195 |
