Fukuda Denshi - DS-7600
by Fukuda Denshi
The DS-7600 series of central monitors lets you stay connected with your patient whether they require telemetry or hardwired surveillance. With their small footprints and large screens, the instruments in this series provide exceptional, flexible monitoring capabilities that make them a superb choice for busy hospital environments. The 15-inch color LCD touch screen displays high-resolution waveforms and alphanumeric data clearly, so data are instantly accessible and easy to input with minimal eyestrain or searching. You can select from 10 user-defined preset display configurations, so regardless of your patient's monitoring needs, the information you need is available at a glance, whether viewing data on a signal patient or on 16 patients at once.
0RepliesSun Nov 14 2021 | disrupted connection to patient The monitor will work on the patient but when the patient lays down it loses connectionReply |
4RepliesFri Aug 26 2016 | Fukuda Denshi Rental Does anyone have a contact for Fukuda Denshi telemetry equipment rental or sale? Preferably rental as we just need to bolster our current capabilities short-term. Reply |
[list] [*] The large 15-inch color LCD makes it easy to view patient data [*] Up to 16 telemetry or hardwired beds can be monitored at one time [*] The easy-to-use touch screen interface makes finding information simple [*] The 3 channel recorder is standard, providing cost effective waveform and graphic trend recording [*] An alarm pole is standard, providing visual notification of prioritized alarm conditions with multiple alarm patents [*] The operational CF card (FCF-1000) provides full disclosure waveform recording. (48-hours data of 16 waveforms, 96-hous data of 8 waveforms) [*] Capable of printing to a networked laser printer through the TCP/IP connection. [/list]
| Height | 397 mm |
| Length | 245 mm |
| Weight | 14 kg |
| Width | 360 mm |
