Siemens - SOMATOM Drive
by Siemens
SOMATOM Drive with Dual Source technology boosts users performance, empowers routines, and expands capabilities.
0Replies8 years ago | Siemens Sensation CT 4 part series – Part 4 Preventative Maintenance Siemens Sensation CT 4 part series – Part 4 Preventative MaintenanceReply |
0Replies8 years ago | Siemens Sensation CT 4 part series – Part 3 Tube Installation Tips Siemens Sensation CT 4 part series – Part 3 Tube Installation TipsReply |
0Replies8 years ago | Siemens Sensation CT 4 part series – Part 2 HV Troubleshooting Tips Siemens Sensation CT 4 part series – Part 2 HV Troubleshooting TipsReply |
[list] [*] Reliable diagnostic results across clinical disciplines as well as a new quality of patient care [*] Easy and fast workflows save preparation [*] The unique Dual Source technology boosts the accuracy of patient radiation [*] Promote optimized performance at all times by simplifying routines and accelerating workflows [*] High-resolution pictures at lowest kV [*] Eliminates metal artefacts in 3D or HD visualizations [*] Unique 10 kV Steps [/list]
Slices | 128 |
Gantry (Max. Clearance) | 78 cm |
Patient Weight Capacity | 307 kg |
[list] [*] Max. scan speed - 458 mm/s [*] In-plane temp.-res. - 75 ms [*] Rotational coverage - 131 mm/rot [*] kV steps - 70 140 kV @ 10 kV Steps [*] mA - @ 70 kV, 80 kV 650 mA, 750 mA [*] Spatial resolution - 0.30 mm [*] Generator power - 200 kW (2 x 100 kW) [/list]
Siemens Healthineers has announced that the Food and Drug Administration (FDA) has cleared the SOMATOM Drive computed tomography (CT) system. This new dual source scanner is designed to drive precision in diagnostic imaging across a wide range of
