Wheelchair
The seat hight is adjustable using the rust and chip resistant quadruple chrome plating process. The Classic 500 comes with 8"x 2" heavy-duty front wheels that won't fall in elevator slots and a reinforced frame including gusseted sides, caster journals and dual cross braces.
- Push to lock brake
- Metal skirt guards
- 24" x 1" heavy-duty urethane rear wheel with composite handrim includes 5/8" (15mm) axle bolt
- Sealed precision bearings on wheels, casters and journals
- Fire retardant, double embossed, Black, heavy-duty, vinyl upholstery
- Padded arm and calf pads are standard
- Threaded seat screw inserts minimize stripping from upholstery changes
- Chart pocket on back
- Ratchet bar to lock leg rests securely in place
Tool-free adjustable, shiny aluminum footplate with push button lock to prevent twisting
| Height | 19.5 inches seat to floor |
| Weight | 74 |
| Patient Weight Capacity | 500 lbs |
| Width | 30 inches overall |
- Seat Width: 22"
- Seat Depth: 18"
- Folded Width: 12.5"
