Olympus - CHF-P60
by Olympus
Ideal for treatment within the bile duct.
Olympus has been an innovator in surgical endoscopes for many years, supplying the first choloedochoscopes for open surgery, the CHF-P60 supplies bright images with a large 2.2mm channel.
[list]        [*] Better Image Quality -Even though the distal end is the same as the CHF-P20 (4.9mm) the number of image fibres has increased by 38% creating better image quality for improved visualisation        [*] Large Instrument Channel for use with the largest range of accessories -The CHF-P60 has the largest instrument channel (2.2mm) of the Olympus range allowing a larger range of accessories to be used for retrieval of larger stones        [*] Compatible with STERRAD® for compliance with new BSG Guidelines -Olympus CHF-P60 choledochofiberscope (with a special identification mark) has material compatibility with STERRAD® 100S/NX sterilization systems and STERRAD® 100NX (when operating on the ‘DUO’ cycle) to comply with the latest BSG guidelines for the sterilisation of invasive endoscopes.        [/list]
Length 570 mm total
[list]  Field of view: 120°        Depth of field: 4 to 50 mm        Distal End Outer diameter: 4.9 mm        Angulation range: 160° up, 130° down        Insertion tube Outer diameter: 5.2 mm        Working length: 380 mm        Minimum visible distance: 5 mm from distal end        Instrument channel Inner diameter: 2.2 mm        [/list]
