Olympus - CHF-CB30L\S
by Olympus
Fiberoptic Choledochoscope
The Olympus CHF-CB30L and CHF-CB30S choledochofiberscopes were developed for translaparoscopic treatment of biliary tract diseases.
-racesurg
8 years ago
Olympus CHF-CB30S/L Choledochoscope Manual
Hi. Can anyone share a copy of the User Manual for the Olympus CHF-CB30S/L Choledochoscope? Thanks.
[list]          [*] Bright, high resolution images - The CHF-CB30L and CHF-CB30S choledochofiberscopes are 1.8 times brighter than the previous generation CHF-CB20 and transmit a bright, clear, high resolution image that ensures a high diagnostic performance and an easy removal of stones in the biliary system          [*] Ultra Slim Diameter for easy insertion into the cystic and common bile duct - The CHF-CB30L and CHF-CB30S choledochofiberscopes are only 2.8mm in outer diameter allowing easy insertion into the cystic and common bile duct          [*] The CHF-CB30L and CHF-CB30S choledochofiberscopes are only 2.8mm in outer diameter allowing easy insertion into the cystic and common bile duct - The CHF-CB30 is available in two separate working lengths to meet all surgical needs. Some surgeons like to control and manipulate the endoscope by twisting the insertion tube and prefer the longer, L-type instrument, while others prefer using the control handle of the endoscope and use the S-type instrument          [*] Large working channel 1.2mm - Despite the narrow diameter of the insertion tube, the CHF-CB30’s has a 1.2mm channel which facilitates distention and the use of a wide range of 3Fr instruments   [/list]
Length 1010 mm (L) 760 mm (S) total
[list]          Field of view: 75°          Direction of view: Direct view          Depth of field: 2.5 - 50 mm          Illumination: Light guide system          Minimum visible distance: 1 mm          Distal end Outer diameter: Ø2.7 mm          Range of tip bending: Up 120° / Down 120°          Insertion tube Outer diameter: Ø2.8 mm   Instrument channel Inner diameter: Ø1.2 mm          [/list]
