Hillrom - VersaCare P3200
by Hillrom
The VersaCare Bed has features to ensure safety for both active and less active patients.
FORUMSView All (23)
-BlakeTheSnake
Fri Oct 02 2026
Stuck in full and Trendelenburg and no other bed functions available
Bed came into shop stuck in full trend. Originally found a code for batteries. Batteries were both shot, so I replaced them and charged for 24hrs. This removed the battery code, but did not change the rest of the issues. Siderail controls are not "locked out". Both scale pods operate normally and bed exits will set. On both siderails, the nurse assist buttons work, but no function buttons do anything. I have isolated both siderails to see if one is causing any issues but no changes were found. I have replaced the Head of Bed main harness (connects the UCB to the siderails and head motor). I have replaced the Coil Cable that connects LCB to UCB. I have swapped out a known good UCB. I have tested the power from transformer to LCB and LCB to UCB. When power is delivered, all panel lights work. When you unplug AC power, normally the bed power will cut out after a few seconds, but DC power will continue and the bed will never "power down" until batteries are disconnected. When the head of bed is manually lifted and AC power is connected, the head motor will automatically turn on and lower itself all the way down. I have not changed the head end Hi-Lo motor, but I feel it doesn't make sense why that would cause all of these issues. I have not replaced the LCB or Transformer either, as I am getting power through both of them to the UCB. I have talked with HillRom tech support and have not had any luck with their offerings. Has anyone ever come across an issue similar to this or have any other ideas? Thankyou for your time.
Equipment: HillRom VersaCare P3200K
-htorres_13
Fri Oct 02 2026
Rails not up
Light indicator not working when both rails are down. Anyone has ever had this happen
-XAVIER101
Sat Feb 07 2026
BED WONT LAY FLAT
MY BED WONT LAY FLAT
Equipment: hILL-rOM 3200
[list]      [*] Patient controls      [*] LowChair: Allows caregiver to keep the bed at the same low position while placing it in chair position      [*] Automatic reactivation      [*] FlexAFoot: Foot platform extender that customizes the bed length up to 12" and helps patients from sliding down the bed      [*] Easy-to-grip side rails      [*] Fixed headboard stays the same - the optimal height for pushing      [*] Hands-free foot controls to adjust bed      [*] Low height that makes getting in and out of bed easier for more active patients      [/list]
Height18 in to 37 inches
Length 82.5 in 94.5 inches overall
Width40 inches with side rails up
Surface Length: 75" to 86"     Sleep Surface Width: 35.5"      Caster Diameter: 5"
