Transfer Master - Valiant HD
by Transfer Master
The Transfer Master Valiant HD is rugged and durable.
This heavy-duty electric bed features adjustable height, head and foot capabilities, making it an ideal choice as a bariatric hospital bed. This full-function electric bed provides users and caregivers complete control through a wired hand control. The Valiant HD is capable of adjusting the High/Low, the Head/Foot and Trendelenburg/Reverse Trendelenburg. A beefed up hospital bed frame and tough lifting mechanisms give this unit a 600 lb. capacity, and the skirt boards around the bottom of the bed frame add style that compliments any decor. The Valiant HD is the best choice for strong and sturdy High/Low beds.                        The Valiant HD hospital bed has an adjustable bed base along with an easily adjustable bed frame, which makes it convenient to set up the bed, wherever required.
[list]            [*] Less than 13.5 inches from deck to the floor            [*] Height range- 10 inches            [*] 5 Function Model            [*] Robust, modular control box design            [*] Tool-free, easy setup split bed            [*] Single or Dual hand controls            [*] ECU Compatible            [*] Compatible with most Hoyer Lift systems            [/list]
Length 80 in
Patient Weight Capacity600 /750 lbs
Width38 in
