Amico - Hydraulic Transfer Stretcher
Transport stretcher
The Amico Hydraulic Patient Transfer Stretcher (S-H-300) provides caregivers the control they need in the emergency environment. The stretchers can be adjusted to various positions raising, lowering, trendelenburg, and reverse trendelenburg by actuating the hydraulic pistons. The back section is adjustable through the use of gas springs and the knee gatch can be raised and lowered with an optional manual crank. The stretcher is made of carbon steel and painted by an electrostatic spray (powder-coat). The base cover is made from injection-molded ABS plastic and the locking siderails are made from a combination of steel, aluminum extrusion and plastic parts for increased durability and to facilitate easy cleaning. The back section includes an X-Ray-compatible board.
[list] [*] Centrally controlled brake system [*] Collapsible siderails [*] Dual side foot pedals [*] Retractable fifth wheel steering system [*] X-Ray compatible backrest [*] Shock absorbing, non-marking bumpers [*] Foley bag holder [/list]
Height | 24 - 37 inch hight range |
Length | 83 in |
Patient Weight Capacity | 550 lbs |
Width | 33 in |
Patient Surface: 75" x 25" Trend/Reverse Trend: 16°
