Ferno-Washington - 35-ANM
by Ferno-Washington
The Ferno Model 35ANM MR conditional cot is designed for use with MRI and in specialized medical treatment areas where the cot must be non-magnetic. Includes all the great features of the standard 35A.
[list] [*] Built in shock frame [*] Manually adjustable back rest [*] Sturdy x frame undercarriage is easily raised by second EMT during loading [*] Lightest cot available with a 500 pound (227 kg) load capacity [*] Built-in shock frame and fully adjustable gas-assist backrest to enhance patient care [*] Safety U-bar and hook holds the Mobile Transporter at the rear of the ambulance during unloading as undercarriage is lowered to the ground [*] Low foot-end lifting frame enables shorter EMTs to get better leverage when lifting the Mobile Transporter Head-end drop frame and foot-end lead handle for improved EMT control/maneuverability [/list]
Height | 9 - 40 inch range |
Length | 63 - 79 inch range |
Weight | 74 lbs |
Width | 24 inches |
