Ferno-Washington - 35X PROFlexX
Ferno 35X PROFlexxFerno’s 35X PROFlexx Ambulance Cot provides industry leading stability and safety. A longer, fixed front leg in the X-Frame and carefully engineered geometry create a low center of gravity and minimal flex. This provides stability to reduce your chances of flipping or tipping a cot during transfers and transport. The 35X EZ Pull™ Release System reduces wrist strain and helps you position yourself before assuming the weight of the cot, so you can maintain proper body mechanics and prevent accidental movement of the legs.
[list] [*] U-Tread wheels [*] Reflective labels [*] Easy-Pull release handle [*] Integrated box beam [*] Strengthened C-Channel [*] One handed side arm release [*] Ratchet bar guard [*] Dual wheel lock [*] Gas assist backrest [*] Powder coated frame [*] Tested to industry standards [*] All-Metal frame [*] Built-in shock frame [*] Stat trac or 175 fastener compatible [*] LBS ready [*] One handed drop frame [*] 5-Position drop frame [*] One handed safety bail release [*] Restraints and mattress included [*] Telescoping side lift handles [*] Backrest adjusts 0 – 65 degrees [*] Wider bed surface and head frame [*] Locked-on mattress [*] Foot-End lead handle [/list]
Height | 34 inch loading hight |
Length | 64 - 79 inch range |
Weight | 92 lbs |
Patient Weight Capacity | 700 lbs |
Width | 24 in |
