Ferno-Washington - 35-XNM Cot
by Ferno-Washington
The Ferno® 35X-NM PROFlexx® Cot is a dual-purpose emergency patient-handling device. The cot is rated MR Conditional at 3-Tesla or less. This means it can be used in magnetic-resonance environments of 3-Tesla or less, under the Listed Conditions of Use. Cam-buckle restraints must be used. The cot can be adapted for use to transport a patient in a ground-based ambulance. Primary restraints that are rated for use in a motor vehicle must be used. The cot is designed for roll-in loading to help reduce the risk of back injury to medical service personnel. The cot is for professional use by a minimum of two trained operators. It is designed for use with the Ferno® Model 175 Cot Fastener Series.
[list] [*] Rated MR Conditional at 3-Tesla or less [*] Manual backrest with seven raised positions [*] Wheel locks (4) [*] Plastic-buckle, cam-lock restraints (3) [/list]
