Ferno-Washington - 35-XST
by Ferno-Washington
Ferno’s 35X PROFlexx X-Frame Ambulance Cot provides exceptional stability and safety when transferring and transporting patients. A longer, fixed front leg in the X-Frame, a rigid C-channel running the length of the cot, and carefully engineered geometry create a low center of gravity and minimal flex. The enhanced stability reduces the chances of tips or flips and other situations that can cause injury to patients and medics.
[list] [*] U-Tread Wheels [*] Reflective Labels [*] Easy-Pull Release Handle [*] Integrated Box Beam [*] Strengthened C-Channel [*] One Handed Side Arm Release [*] Ratchet Bar Guard [*] Dual Wheel Lock [*] Gas Assist Backrest [*] Powder Coated Frame [*] Tested to Industry Standards [*] All-Metal Frame [*] Built-in Shock Frame [*] Stat Trac or 175 Fastener Compatible [*] LBS Ready [*] One Handed Drop Frame [*] 5-Position Drop Frame [*] One Handed Safety Bail Release [*] Restraints and Mattress Included [*] Telescoping Side Lift Handles [*] Backrest Adjusts 0 – 65 degrees [*] Wider Bed Surface and Head Frame [*] Locked-on Mattress [*] Foot-End Lead Handle [/list]
Height | 34 inch loading hight |
Length | 64 - 79 inch range |
Weight | 92 lbs |
Patient Weight Capacity | 700 lbs |
Width | 24 in |
