Ferno-Washington - PowerFlexx+
POWERFlexx+ Powered Ambulance CotThe POWERFlexx™+ System delivers advanced power management and features an in-the-fastener charging to keep you powered on every call, without having to carry around extra batteries or take them out to charge. As soon as you lock into the fastener, The ICS Integrated Charging System charges the battery. The POWERFlexx+™ Powered Ambulance Cot also features 700lb unassisted lift capacity. The cot lifts the 700 lb. weight, not the operators, reducing situations where operators may injure their back.
[list] [*] 5-Position head end load frame [*] Elongated rectangular X-Frame [*] Non-Telescoping tubing [*] Reflective labeling [*] 360° turn radius [*] Ergonomic control panel at operator end [*] 24V Lead acid battery system [*] Auto shutoff during charging [*] Battery charger indicator [*] Clear anodized upper mainframe [*] No pinch points along mainframe [*] Manual override mode handle with secondary lock [*] One hand sidearm release [*] Swing out sidearms lock at 90° [*] X-Frame runs on 4 shafts using linear bearings [*] Dual piston actuator [*] Extra-Wide backrest panel [*] Mattress retained by locking clips [*] 79″ Patient surface / mattress [/list]
Height | 33 inch max loading hight |
Length | 61 - 83 inch range |
Weight | 133 lbs |
Patient Weight Capacity | 700 lbs |
Width | 24 inches |
