Ferno-Washington - PoweFlexx Stattrac
POWERFLEXX STATTRACThe POWERFlexx Powered Ambulance Cot provides 700 lb unassisted lift capacity. The cot lifts the 700 lb weight, not the operators, reducing situations where medics may injure their back. Advanced power management and in-the-fastener charging to keep you powered on every call, without having to carry around extra batteries or take them out to charge. As soon as you lock into the fastener, the ICS Integrated Charging System charges the battery.
[list] [*] 5-Position Head End Load Frame [*] Elongated Rectangular X-Frame [*] Non-Telescoping Tubing [*] Reflective Labeling [*] 360° Turn Radius [*] Ergonomic Control Panel at Operator End [*] User Intuitive Color Controls [*] On/Off Switch on Operator Panel [*] Power Pack Located Under Backrest [*] 24V Lead Acid Battery System [*] Auto Shutoff During Charging [*] Battery Charger Indicator [*] Clear Anodized Upper Mainframe [*] No Pinch Points Along Mainframe [*] Manual Override Mode Handle with Secondary Lock [*] One Hand Sidearm Release [*] Swing Out Sidearms Lock at 90° [*] X-Frame Runs on 4 Shafts Using Linear Bearings [*] Dual Piston Actuator [*] Extra-Wide Backrest Panel [/list]
Height | 34 max loading hight |
Length | 61 - 83 inch range |
Weight | 133 lbs |
Patient Weight Capacity | 700 lbs |
Width | 24 in |
