Hillrom - Durastar P8005
by Hillrom
This product is Discontinued
Transport Stretcher
Hill-Roms Transport Stretcher is an economical choice designed with ease of use and versatility in mind. Our industry leading warranty provides you with confidence in the durability and craftsmanship of our stretcher fleet.                The Next Generation Steering Plus System on Hill-Roms Transport Stretcher is easy to steer and stop while allowing for crisp cornering and control. Increased stability is provided through the dual-locking four wheel braking system, which is standard on all Hill-Rom Stretchers.                Built to last, the transport stretchers heavy-gauge, automotive-grade steel reinforced frame provides both long-lasting quality and a 700 lb. weight capacity to handle patients of varying size. The stretcher integrates well with other emergency room equipment, making it an ideal ER and transport stretcher.
[list]        [*] Integrated utility try        [*] Integrated O2 tank holder        [*] Low deck hight capability        [*] Redundant-locking, four-wheel brakes        [*] Power washable        [*] Break/Steer pedals all four sides        [*] permanent IV pole - 2 stage  [/list]
Length 83 in
Patient Weight Capacity700 lbs
Width32 to 36 inches
Siderail length: 47"        Siderail hight above deck: 14.5"        Maximum head elevation: 90°        Maximum Trendeleburg/Reverse Trendelenburg: 18°        Floor to base clearance: 3.5"        Caster size: 8"
