Penlon - Prima SP2
by Penlon
The Prima SP2 Anesthesia Machine provides sophistication in a flexible, easy-to-use system, designed to meet all anesthesia requirements.
3RepliesWed Dec 20 2017 | Integration Manuel por HL7 Driver for connectivity Is it possible to get the Integration Manuel or HL7 Driver for connectivity for the models are mentioned. Thank you in advence...Reply |
3RepliesTue Jan 19 2016 | AVS Vent with no display Has anyone encountered a vent display that is unresponsive? It is model AV-S (ventilator). I'm being told it is main board, and will cost around $5500 for board. On top of that it may require "an updated video board", for $2200. This is a refurbished unit, around 2 yrs old. Not sure of model year. Here are my questions: 1) Is this cost fair? 2) Should I pay cost, or consider a refurbished ohmeda of drager unit? This machine was extremely lightly used. I'm talking about...we NEVER used it for a case! 3) Is there an alternative to having a full on digital vent monitor with all the vent modes? Thanks Denis Reply |
0RepliesThu May 28 2015 | Circuit diagram for Penlon Prima SP2 Motherboard. Hi.. Where i can get the circuit diagram for Penlon Prima SP2 Motherboard. Reply |
| Height | 54 in |
| Gases | Air, Carbon Dioxide, Nitrous Oxide, Oxygen |
| Length | 31.5 in |
| Vaporizers (Max) | Three |
| Weight | 165.4 lbs |
| Vaporizer Type | Electronic control |
| Vent Modes | Spontaneous, Volume, Pressure, Pressure Support, SIMV, SMMV |
| Width | 28.4 in |
