GE HealthCare - Dash 3000
by GE HealthCare
Advanced capabilities allow you to reliably move a patient throughout your enterprise, while feature-rich, no-compromise performance at the bedside helps maximize equipment utilization. Weighing only 5 kilo's, regardless of configuration, this lightweight monitor is made to move with a patient. The compact, ergonomic package, complete with integral power supply, allows easy handling. And drop-test rugged design means Dash 3000 is made to withstand your demanding portable applications. An extensive feature set enables you to create a portable monitoring solution capable of meeting a wide range of acuity demands. Many features you would only expect to find as options elsewhere are standard on Dash 3000 - including 3 and 5 lead ECG, pulse oximetry, noninvasive blood pressure, two temperatures and respiration. Dash 3000 also accommodates two invasive blood pressures, mainstream CO2 monitoring, and your choice of full arrhythmia, true 12-lead ECG with enhanced ST segment analysis, cardiac output and PA wedge procedures.
3RepliesThu Mar 11 2021 | Blank screen on Dash 3000 I have a Dash 3000 with a blank screen. It seems the rest of the unit works since I can push the NIBP button and it starts to inflate but I see nothing on the screen. The AC LED is lit.Reply |
2RepliesThu Apr 02 2020 | Co2 Sensor? Has anyone seen or know where to get the Co2 sensor for the dash 3000? Is this the same as EtCo2? Confused as there is no place for a water trap.Reply |
0RepliesSun Jan 27 2019 | Software 7.3 update Anyone have this to update from 7.2? I have 2 units that are having the boot looping problem. I read that GE is supposed to provide the update for free, but am thinking the likelihood of getting it, unless Im willing to pay them big bucks, is less than the chance of winning the lottery. I dont have an account with GE, so I wont get anywhere with them. Is it installed with the cold boot via the Ethernet port? ThanksReply |
