Sorvall - RC 6 Plus
by Sorvall
Run conditions are selected using the touch keyboard. Actual and set run conditions are displayed. For your protection, system interlocks keep the centrifuge from starting if the chamber door is open, and prevent the door from being opened if a run is in progress and the rotor is spinning. System interlocks will also automatically terminate a run in progress if a system malfunctions. The RC6 Plus drive system has a high-frequency brushless motor for fast separations and reduced maintenance. The refrigeration system, charged with environmentally- friendly CFC-free SUVA® refrigerant, offers reliable performance similar to other Thermo Scientific Superspeed centrifuges. The high-capacity refrigeration system is a low temperature, hermetically-sealed unit that consists of a compressor, a condenser, an evaporator/rotor chamber, and interconnecting tubing. When the centrifuge is running, the refrigeration system will maintain selected temperatures within the range specified for the centrifuge.
0RepliesFri Jun 02 2023 | Access Control We just picked up an RC 6 Plus at auction but the control is locked out. Does anyone have the Access Control manual or at least know if there's a general admin ID and password we can use in order to reset the Access Control and run the instrument? Reply |
8RepliesSat Nov 20 2021 | Open door alarms beeping open door alarm won't stop even when the door are closed. it's a sorvall RC6 any advice? How to open the door? I turned it off and turned on still cant open door.Reply |
6RepliesTue Nov 17 2020 | Drive Crown How to replaceReply |
[list] [*] Meets all CE and CSA safety requirements without bolting the unit to the floor [*] Powerful refrigeration system keeps samples from damage due to heat or freezing [*] Compatible with many Sorvall RC-6 and RC-5 series rotors [*] Corrosion-and fatigue-resistance [*] Rotors are compatible with Thermo Scientific Nalgene bottles and tubes for complete centrifuge solutions [/list]
| Height | 1112 mm |
| Length | 835 mm |
| Weight | 350 kg |
| Maximum Speed | 22000 rpm |
| Width | 757 mm |
