Atlanta BioMedical Corporation - 4100E
by Atlanta BioMedical Corporation
The pump recognizes all enteral syringe manufacturers and accepts all sizes from 1 thru 140 ml. The pump is made of metal for durability and can be mounted onto any pole/rail system. Numerous features readily identify the pump as enteral. The pump has several potential levels to improve the safety of enteral deliveries. The pump can be customized to meet the specific needs of your clinical environment. If clinically required, the pump's position can easily be changed to enhance the delivery of human breast milk by using the rotating pole clamp to orient the syringe in a vertical position.
[list] [*] Multiple enteral delivery modes [*] Several enteral safety messages [*] Accommodates various enteral syringes [*] Easy syringe loading [*] Multiple sensors to monitor delivery accuracy [/list]
| Volume to be Infused | 1 to 140 ml |
| Height | 3.95 in |
| Length | 5.9 in |
| Weight | 4.99 lbs |
| Flow Accuracy | 3 % |
| Width | 9.5 in |
