Cynosure - Apogee+
by Cynosure
High-powered Apogee®+ Aesthetic Workstation
The Apogee+ boasts higher power and speed, providing practitioners with up to 20 J/cm2 at an 18 mm spot size and 2 Hz.                    The clinical proven 755 nm Alexandrite laser’s high melanin absorption characteristics and proven long-term results make it a wavelength for excellent hair reduction, permanently reducing hair by an average of 79% after just three treatments.1                    The 755 nm Alexandrite can also provide excellent clearance of epidermal pigment lesions, including age spots, sunspots, and freckles.
-Hera.co
4 years ago
Service manual
Hi There, Would be greatly appreciated if someone can share the service manual of this device with me. Thank you,Reply
-TJ78
8 years ago
Operator Manual
Does anyone have a Cynosure Apogee Elite + (plus) operator manaulReply
[list]          [*] Quick, Effective Treatments          -The Apogee + is built on the proven technology of the Apogee Aesthetic Workstation but provides high fluence with large spot sizes for deeper penetration, faster procedures, and optimal results          [*] Customized Treatments          -Apogee’s variable spot sizes and pulse widths allow for complete customization of procedures based on client hair and skin type—for optimal outcome efficiency          [/list]
Laser TypeAlexandrite
Height41 in
Length 25 in
Weight180 lbs
Wavelength755 nm
Width15 in
Pulse Width: adjustable 0.5-300 msec          Maximum Fluence Per Spot Size    -18mm: 20 J/cm^2          -15mm: 30 J/cm^2          -12mm: 45 J/cm^2          -5mm: 50 J/cm^2          Maximum Rep rate: 3 Hz          Aiming Beam: Red          Skin Cooling System: Cold Air          Electrical Requirements: 208/240 VAC/30A
