Penlon - Prima SP 101R
by Penlon
Rail and Wall models take the specification of the compact anesthetic machine to new heights
-NJOGU
Wed Apr 18 2018
Vaporizer calibration
how do you calibrate the vaporizer, and how often should it be done.Reply
[list]   [*] Compact rail mounting, can be mounted on a pendant system   [*] Mechanical Anti-Hypoxic Device (AHD)   [*] Optional Cascade Flowmeter - Oxygen, Nitrous Oxide and Air   [*] Optional cylinder yokes (Wall machine only)   [*] Up to three gases   [*] Monitor shelf and work surface   [*] High Common Gas Outlet (CGO)   [*] Optional built-in Oxygen Monitor   [*] Complies with all appropriate International Standards   [/list]
Height590 mm
GasesAir, Carbon Dioxide, Nitrous Oxide, Oxygen
Length 430 mm
Vaporizers (Max)One
Weight35 kg
Vaporizer TypeElectronic control
Vent ModesOff, Standby, Volume, Pressure, Spontaneous
Width585 mm
