Air Liquide Healthcare - ALYS 2000
by Air Liquide Healthcare
ALYS 2000 adapts to all situations, from new-born to adult.
ALYS 2000 has two modes of controlled ventilation - volume (VC) and pressure (PC),both of which are very efficient thanks to a high inspiratory flow rate. At each stage of anesthesia ALYS 2000 ensures precise monitoring of ventilation with particularly safe spontaneous ventilation.
FORUMSView All (3)
-samer asim
10 years ago
Alarm12 driving gas
alaram 12
driving gas
i need manual or suggestion or steps to flow?
-ahmed.sarfraz@hotmail.com
11 years ago
required flow board for Alys 2000
i need flow board which is inside of the machine, and also used in the calibration of inspiratory flow board. kindly help and send me the price on the mentioned email.
-alkendi hos
14 years ago
peep volve borde
i want an peep volve bordeReply
[list]  [*] Choice of ventilation modes - ALYS 2000 has two modes of controlled ventilation - volume (VC) and pressure (PC),   both of which are very efficient thanks to a high inspiratory flow rate. At each stage of anaesthesia ALYS 2000 ensures precise monitoring of ventilation with particularly safe spontaneous ventilation.   [*] Simplicity of use - ALYS 2000 has an easy to use control panel,with a display that clearly shows patient ventilation and the various alarms thanks to dedicated display areas. For greater comfort ALYS 2000 is equipped with a rear-lit 5-tube rotametric mixer that ensures fine and rapid fresh gas adjustment.   [*] Optimum design - ALYS 2000 enables optimum integration of all monitors and accessories. ALYS 2000 has plenty of work space and practical storage drawers.  [/list]
Height53 in
GasesAir, Nitrous Oxide, Oxygen
Length 27 in
Vaporizers (Max)Two
Weight220 lbs
Vent ModesManual / Spontaneous, VC, PC, VCI, PCI
Width32 in
