Air Liquide Healthcare - Clarys 2000
by Air Liquide Healthcare
Need modularity in your operating room?
Suspended CLARYS 2000: the optimal operating theater layout. Due to its low weight, CLARYS 2000 can be attached to a medium-capacity ceiling-mounted distribution arm.This configuration provides freedom of movement and space due to the integrated electrical, pneumatic and IT connections.CLARYS 2000's design enables easy assembly, disassembly, upkeep and maintenance.      Mobile CLARYS 2000: Remarkably easy to handle due to its compact size and low weight. Its tubular structure enables easy integration of the various items of equipment and accessories. Thanks to this modular design, CLARYS 2000 can be configured according to your requirements.
FORUMSView All (5)
-hadoudi21@gmail.com
a year ago
Technical manual
Can anybody help me i need tchnical manual for taema clarys thank you very much
Equipment: Taema clarys
9 years ago
manual service
please if anybody can help me a service manual of clarys 2000 thanks
-azhar
13 years ago
Spares requirement
I request the following spares;
  Flow sensor,  Expiratory valve
[list]  [*] Choice of ventilation modes - CLARYS 2000 has two modes of controlled ventilation - volume (VC) and pressure (PC), both of which are very efficient thanks to a high inspiratory flow rate. At each stage of anaesthesia CLARYS 2000 ensures precise monitoring of ventilation with particularly safe spontaneous ventilation. CLARYS 2000 adapts to all situations, from new-born to adult.  [/list]
Height52 in Mobile unit
GasesAir, Nitrous Oxide, Oxygen
Length 29 in Mobile unit
Vaporizers (Max)One
Weight154 lbs Mobile unit
Inspiratory Flow (max)80 L/min
Vent ModesManual, spontaneous, VC, PCV
Width29 in Mobile unit
