Draeger - Fabius Plus
Combine quality ventilation, easy operation and maintenance with open architecture expandability. The Dräger Fabius® Plus combines quality ventilation with enhanced flexibility and integration capabilities. It was designed to accommodate a wide range of options and accessories, allowing you to customize your Dräger Fabius® Plus to suit your particular needs.
FORUMSView All (7)
1Reply7 months ago | I have problem in draeger - fabius plus Anastasia ventilator It says ventilator fail Check apl/EXT. Fgo Reply |
1Reply2 years ago | pressure mode Dear. After replacing the 3v battery of a Fabius Plus anesthesia station, the equipment did not access pressure mode. I checked all the configuration of the service mode and are the same as the other equipment. Can anyone help me?Reply |
0Replies3 years ago | O2 housing Required o2 housingReply |
[list] [*] Powerful, accurate ventilation without drive gas [*] Modular open architecture and connectivity [*] Enhanced safety features [*] Designed around your workflow [*] Comprehensive information management [/list]
