Stephan - Akzent
by Stephan
The Anesthesia System for Newborns and Adults
As technology progresses and quality requirements continue to rise, so do the demands towards the effectiveness and efficiency of economical and time-saving anaesthesiology.
With AKZENT, F. Stephan GmbH has developed a modern anaesthesia system in which the users' widely differing requirements are met by a single, very compact device. For the sake of process optimization, all operating modes are selectable via a single, centrally located knob, thus permitting not only rapid, but also extremely secure handling. With AKZENT, the hospital is investing in a system able to cover a broad spectrum of not only newborn but also adult anaesthesiology needs.
Turning a single knob allows the operator to switch between manual ventilation, rebreathing or non-rebreathing systems as well as a supplemental fresh gas outlet. This allows for the user to get greater precision in the control of the anaesthetic process and a more flexible reaction to unexpectedly changing conditions.
The integrated, clearly laid out electroluminescent display (EL) allows the defined ventilation parameters to be easily evaluated in relation to the monitored parameters (numeric/graphic). All process-related data are available at a glance. The goal is to allow the user to quickly and efficiently make a clear evaluation and to thus optimize patient safety.
-SME
4 years ago
service manual
Hi everyone Please someone who has Stephan GmbH - Akzent color Service Manual send it to my email yshamali@hotmail.com machine did not pass calibration and when pass ventilator fail to start or stsrt 2-3 cycles , I need assistance please do support appreciate any respposne best regards Dr.Yahya Reply
  • Intelligent, intuitive operating concept
  • Integrated, heated ventilation system
  • Ergonomic design
  • Compact, slim shape
  • Graphic monitoring
  • Tidal volumes starting at 10 ml (optional)
Height55.1 in Mobile unit
GasesAir, Nitrous Oxide, Oxygen
Length 9.44 in Mobile unit
Weight99.2 lbs Mobile unit
Vent ModesV-CMV Pressure curve: linear, square wave Leakage compensation P-CMV Pressure curve: linear, square wave SIMV
Width29 in Mobile unit
Power supply
Mains 90-240 V AC, 50-60 Hz, 110 VA
Battery 12 V DC, approx. 2 hr.
Optional approx. 30 min. with Anesthetic
gas measurement module
Gas supply
AIR 3 - 6 bar + 0,5 bar
O2 3 - 6 bar + 0,5 bar
Optional
N2O 3 - 6 bar + 0,5 bar
